Dodge B100 van question
https://www.slantsix.org/forum/viewtopic.php?t=52897
Page 2 of 2
Author:  Reed [ Tue Aug 06, 2013 2:31 pm ]
Looking at those pictures and hearing that the air injection port on the head is capped, I would say that what you have is a relief valve, not a diverter valve. However, your vacuum diagram shows a hose going from the valve to the carb, so I would look for an unused fitting on the carb that would fit the hose from the valve. The carburetor section in your factory service manual will have a diagram showing all the ports on the carburetor and indicating what attaches to each port.
The AIR injection systems in the late 70s and into the 80s are confusing because there were many variations depending on the equipment ordered on the vehicle and the final market.
Author:  Mpatch [ Tue Aug 06, 2013 7:56 pm ]
After some testing I figured out it is a diverter valve in a sense, it cuts airflow when you let off of the accelerator. I think this is to prevent backfiring.
Author:  Reed [ Tue Aug 06, 2013 9:54 pm ]
Yep, sounds like a relieve valve venting the AIR pump discharge to the atmosphere like it should.
Page 2 of 2 All times are UTC-08:00
