It is currently Wed Dec 31, 2025 10:56 pm
PostPosted: Tue Oct 08, 2013 4:29 am
I will make an addition to MPGFanatics car/engine. I have been driving the car to a few local cruises. I did change out the points distributer, for an HEI conversion. Just used a distributer I had (unkown curve). With the initial timing set where the engine has good idle, and low speed pull, in first gear (3 spd stick) , it will ping in high on level ground with moderate throttle. I have had to use 89 octane fuel. I do need to recurve the distributer.
 Post subject: Yep...
PostPosted: Tue Oct 08, 2013 8:19 am
That is very typical of the long slot 1973-1975 distributor to ping in the mid-range throttle (and worse if you have a 1974 Holley 1945 with the #58 stock jetting). This is one reason I prefer to swap it out with a short slot later distributor, or recurve the long slot and put a short looped spring in to limit the advance. This also can be solved by moving the posts outward putting more tension on the spring and slowing the advance but then the engine loses it's "pep" so it's a band-aid not a cure.
:wink:
PostPosted: Wed Oct 09, 2013 6:06 am
I'm reading and digesting comments, keep'em coming.
I haven't seen any combos with 3.55 gears. Would the lower rear gear 3.55 lessen pinging, or exacerbate detonation all things being equal compared to some of the examples of heavy cars with 2.xx gearing listed?
 Post subject: gearing
PostPosted: Wed Oct 09, 2013 7:07 am
"Performance" gearing lessens the amount of work the powertrain has to accomplish to motivate the car, decreasing the load on the engine when accelerate. It also moves the cruise rpm of the engine higher so that the cam must be chosen to provide a powerband that coincides with the gearing as well (thus the distributor curve and carb profile should match this as well for optimum performance).
My original supersix build for the blue duster would ping in the midrange with a stock late distributor and 2.94 gearing, switched to 3.55's and the ping went away (more fun to drive, car was easier to move).
-D.idiot
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
