| Slant Six Forum https://www.slantsix.org/forum/ |
| Another High Temperature Question https://www.slantsix.org/forum/viewtopic.php?t=5357 |
Page 2 of 2 |
| Author: | Doc [ Tue Apr 08, 2003 11:45 am ] |
The best way to backflush a radiator yourself is to remove it from the car and use your garden hose to wash it out. Turn the radiator up-side-down and insert the hose into the bottom outlet, wrap a rag around it to seal that end, then turn the hose on full blast. Shake the radiator around to help get any crud to come out the cap opening. You can also remove the thermostat cover and do the same process to the engine block and the heater core. Prestone sells a backflush kit that helps you do a backflush without removing the radiator but I find that it is hard to get the big chunks to come-out the top when using their kit. DD |
| Author: | Dart270 [ Wed Apr 09, 2003 5:06 am ] |
Erik, Maybe I missed it, but did you post the buildup specs of your motor? No hurry, but I'd like to see specifically what you used. Thanks, Lou |
| Author: | PlumCrazy71 [ Wed Apr 09, 2003 12:33 pm ] |
| Post subject: | Engine Buildup |
Lou and all, Engine buildup: 68 225 block and head Bored 30 over Head shaved 90 SBC Valves - I think they ended up 1.72I/1.50E 340 Springs MP 268 cam Silvolite pistons Stock rods Cox bros true double roller timing chain (what a thing of beauty) installed with cam advanced 2 degrees (per one of Doc's old messages) J&M windage tray (figured I'd do it while everything was open (another thing of beauty)) Clifford 4bbl intake Edelbrock 500cfm carb (stock jets, may need to do some playing but seems to be working okay) Clifford street rod headers Dual 2-1/4" pipes from header out w/ Flowmaster Delta 40's 10" Midwest verter (per Dennis' specs I think (stall around 2500)) (also a thing of beauty) Stock 904 and finally (I hate to mention this part) stock 7-1/4 rear w/ 2.76? gears To be done someday soon I hope: Disc brakes and 8-3/4 w/ 3.55 gears (Should have done this stuff before the engine, but stopping is overrated). Thanks again to all who offered me advise along the way. Erik |
| Author: | PlumCrazy71 [ Fri Apr 11, 2003 11:19 pm ] |
| Post subject: | See Slixer's Gallery |
04-11-03 Update Just finished adding all of the information above, along with pictures, to the Slixer's Gallery. Thanks, Erik |
| Page 2 of 2 | All times are UTC-08:00 |
