| Slant Six Forum https://www.slantsix.org/forum/ |
| Intake/Exhaust manifold studs https://www.slantsix.org/forum/viewtopic.php?t=55252 |
Page 2 of 2 |
| Author: | hyper_pak [ Tue Nov 27, 2018 5:06 pm ] |
| Post subject: | Re: Intake/Exhaust manifold studs |
Funny, first post says source is "AARP"! I know these are old engines, but "AARP"? |
| Author: | SpaceFrank [ Tue Nov 27, 2018 6:01 pm ] |
FYI, all the posts before '82 Power Ram are over 4 years old; he resurrected an old thread. |
| Author: | '82 Power Ram [ Wed Nov 28, 2018 2:28 pm ] |
Quote: If you mean the studs in the head that the intake and exhaust manifolds mount to, as far as I know they are all the same size. Granted that hasn't stopped me from using a longer stud in a pinch, then adding a washer or two between the nut and the triangle washer.
| Author: | '82 Power Ram [ Wed Nov 28, 2018 2:31 pm ] |
Quote: The studs are all the same size.
The key is making sure that the correct washer and fastener is used when re-assembling. Fat circle washers and BRASS nuts go on each end on top, there is 1 fat circle washer with a regular nut smack in the middle on top, the remainder get triangle washers and regular nuts. Be sure not to over-tighten the manifolds. ~THOR~ |
| Author: | Rick Covalt [ Wed Nov 28, 2018 4:18 pm ] |
Do you have questions about the quotes??? |
| Page 2 of 2 | All times are UTC-08:00 |
