It is currently Thu Jun 25, 2026 7:12 pm
PostPosted: Fri Jul 23, 2004 5:54 pm
yes, brand new ballast resister.
PostPosted: Fri Jul 23, 2004 8:37 pm
Are you running electronic ign? If so it sounds like the pickup coil in the dist or the module. That is assuming the wireing is correct.
PostPosted: Sat Jul 24, 2004 3:00 am
The problem was the ignition control module. I changed that out today and now I am getting a perfect spark and I'm sittin pretty. I still haven't fired it up but my battery was low so I'm going to try again tomorrow. Thanks for all the help, I'll let you know when I start up.
PostPosted: Sat Jul 24, 2004 8:29 pm
The struggle has ended :D This motor sounds like one bad mother. Thanks a lot for the ideas, they helped a ton.
