Starting a new motor
https://www.slantsix.org/forum/viewtopic.php?t=9831
Page 2 of 2
Author:  Slantosis [ Fri Jul 23, 2004 5:54 pm ]
yes, brand new ballast resister.
Author:  Charrlie_S [ Fri Jul 23, 2004 8:37 pm ]
Are you running electronic ign? If so it sounds like the pickup coil in the dist or the module. That is assuming the wireing is correct.
Author:  Slantosis [ Sat Jul 24, 2004 3:00 am ]
The problem was the ignition control module. I changed that out today and now I am getting a perfect spark and I'm sittin pretty. I still haven't fired it up but my battery was low so I'm going to try again tomorrow. Thanks for all the help, I'll let you know when I start up.
Author:  Slantosis [ Sat Jul 24, 2004 8:29 pm ]
The struggle has ended :D This motor sounds like one bad mother. Thanks a lot for the ideas, they helped a ton.
Page 2 of 2 All times are UTC-08:00
