No I don't work for Zmax
https://www.slantsix.org/forum/viewtopic.php?t=16914
Page 4 of 4
Author:  dakight [ Sat Apr 08, 2006 8:40 am ]
The Dupont oil engineer told me that is the best oil for the money on a new engine or a rebuild after break in.
I believe that Mobile 1 is the original fill in BMW as well as some other high dollar imports. It's what I use in my vehicles.
Author:  HyperValiant [ Sat Apr 08, 2006 9:03 am ]
The only reason I asked about Lucas was that I have a couple of vehicles that set for long periods between startups and was thinking about the the dry startup issues,after reading that link I beleive Ill just use quality motor oil and pray for the best.Thanks Dan.
HyperValiant
Author:  dakight [ Sat Apr 08, 2006 10:22 am ]
A thickener like Lucas or STP will make that problem worse because they thicken the oil and slow it circulation.You'd be better off with a thinner oil. You could prime the oil pump with vaseline or light grease then spin it over for a few seconds with the plugs out to pump some oil up into the bearings and camshaft. When I was working on phords we used to pull the distributor and spin the rod with an electric drill until oil was circulating. Can't do that with a slant.
Page 4 of 4 All times are UTC-08:00
