| Slant Six Forum https://www.slantsix.org/forum/ |
| Howell EFI kit install (Edit: swapped for MS now w/mpfi) https://www.slantsix.org/forum/viewtopic.php?t=5212 |
Page 4 of 4 |
| Author: | Pierre [ Wed Sep 14, 2005 8:28 pm ] |
| Post subject: | Out with the old, in with the new... |
Almost done... only thing left is to tighten the manifold/headers down, do the plumbing, and the wiring. Sorry pictures are big, I tried to use the width= using straight html code but it didn't seem to take. |
| Author: | sandy in BC [ Wed Sep 14, 2005 9:13 pm ] |
Very Cool! Lotsa inovative hard work. You my hero today. |
| Author: | Pierre [ Sun Sep 18, 2005 2:59 pm ] |
I've put about, oh, 250 miles or so on the setup so far. All I did tuning wise was set req_fuel , didn't work much on anything else. Need to fuss iwth the Accelerator encrichment and cold start params, but the driveability is good, excellent torque. |
| Author: | Dart270 [ Mon Sep 19, 2005 6:36 am ] |
Congrats, Pierre! You have some work to do with tuning, but it will pay off. Lou |
| Author: | Pierre [ Thu May 04, 2006 7:32 pm ] |
| Post subject: | Doot doot, humming along |
Latest updates to this mpfi business - megasquirt is now where the glove compartment was - I got tired of it sitting on the floorboard so I finally found a home for it in the dash. Pretty soon I will be getting rid of the relay board (I really don't like the type of screw connectors on it) and wiring everything directly to the board I mounted the computer on under the dash. Also redid intake plumbing - http://home.inreach.com/~pierre/airclea ... erside.JPG http://home.inreach.com/~pierre/airclea ... rfront.JPG I can now feel confident driving the car with one foot. Once I re-routed the fuel return from the pump input directly into the tank, hot idle is plenty stable now. Every now and then I plug the computer in and tweak the tuning, still needs some work to be 100% solid but tis a never ending adventure of fun |
| Author: | Hyper'72Valiant [ Fri May 05, 2006 12:52 am ] |
Nice Pierre!!!! Cory |
| Author: | Chuck [ Thu Jun 01, 2006 12:22 am ] |
| Post subject: | Re: Out with the old, in with the new... |
Quote: ... Sorry pictures are big, I tried to use the width= using straight html code but it didn't seem to take.
Pierre, the "width=" doesn't work anymore (don't know why) but a recent software update resizes your pictures automatically and allows you to click on the picture to load the larger image.
| Author: | GunPilot [ Sun Jun 04, 2006 9:22 am ] |
Nicely done... way to persevere on a project and see it through. Did you document how you got your MP injectors/fuel rail hardware set up? Did you have the fuel rail made or did you fab it? I have been running MS for 2 years on a '77 Ramcharger and love it. MS is the way to go. My Duster will have MS injection and spark control. Good Job!! |
| Author: | Pierre [ Sun Jun 04, 2006 10:49 am ] |
The fuel rail and manifold came as you see it in the pictures from clifford direct. They apparently at one time were going to sell mpfi setups and they made a limited run of mpfi manifolds and rails. Those plans fell through - he gave me the manifold with bungs already drilled for same price as a regular one, and fuel rail for an extra $20. Only thing I "manufactured" were those hold downs and adapter plate for throttle body. Those aren't MP injectors, they are 22lb ford/denso injectors from www.fiveomotorsport.com Other than what's in this thread I don't have anything documented.... feel free to ask me anything here. |
| Author: | SlantSixDan [ Sun Jun 04, 2006 11:06 am ] |
Wow. Truly awesome work. Thanks for sharing the ongoing reports! |
| Author: | Pierre [ Sun Jun 04, 2006 9:29 pm ] |
Wow... thanks for the compliments, I thought my installation was craptacular personally.... The bundymobile is downed for a while, hole #4 had 60 psi compression, 100 less than the rest, due to jacked up exhaust valve/seat. Getting complete rebuild done, should have the engine back within 2 weeks. Should make the EFI easier to tune.... I may do little stuff in the meantime while engine is out, cleaning up engine bay, wiring, etc. We shall see. Eager to get the new mill back in! |
| Page 4 of 4 | All times are UTC-07:00 |
