Fix For Power Steering Gearbox Leak?
https://www.slantsix.org/forum/viewtopic.php?t=10227
Page 1 of 1
Author:  Spazus [ Wed Aug 25, 2004 11:05 pm ]
Post subject:  Fix For Power Steering Gearbox Leak?
Hi Gang,
I have a power steering gear box that leaks fluid all over the place from the sector shaft adjusting screw. This pic should explain it all. I have tried on more than one occasion to tighten the nut and it still leaks. I might have tweaked something by overtightening. How might I fix this problem outside of replacing the whole unit? I could keep adding fluid but I hate the thought of polluting the reasonably pristine Oregon environment.
Tom
Author:  Slant6Ram [ Thu Aug 26, 2004 10:42 am ]
Post subject:  Try....
Try a brass plumbing washer. Might help, depending on why it's leaking.
Author:  Craig [ Thu Aug 26, 2004 8:10 pm ]
There is usually an aluminum ID tag under the nut that also works as a seal. I don't remember right now if the center of the hole in the ID tag has a rubber center or not.
Either way, looks like yours is missing.
Author:  DusterIdiot [ Thu Aug 26, 2004 8:17 pm ]
Post subject:  What year?
What year box/car?
Just curious I might have a spare you could have in 'the shed'...
Author:  Eric W [ Thu Aug 26, 2004 9:27 pm ]
Uh-oh, not "The Shed"! :shock: :wink:
Author:  Dennis Weaver [ Fri Aug 27, 2004 7:26 am ]
There is also an o-ring seal under that cover (two really, one for the cover and one for the screw), but the cover must be removed to access the one for the screw, if I remember correctly.
D/W
Author:  Slant6Ram [ Fri Aug 27, 2004 8:48 am ]
Post subject:  The shed
I'm with Eric,
Why is he going in the shed?!!!! Doesn't he hear the scary MUSIC!!!! :shock:
:lol: :lol: :roll:
Author:  Spazus [ Tue Aug 31, 2004 9:13 am ]
Post subject:  Fixed
Thanks guys. I put an extra rubber o-ring under the nut and now have no more leaks. I was just worried that I would loosen something and parts would fly everywhere.
Tom
