It is currently Fri Jan 02, 2026 7:38 am
PostPosted: Tue Mar 15, 2011 11:03 am
Where have some of you mounted your tachometers in your early a-body?
I need to get one but would like to see some pics of how you mounted yours. This is a street car. Pics welcome.
PostPosted: Tue Mar 15, 2011 1:37 pm
1965 Dart, steering column between the turn signal stalk and the dash.
 Post subject: Where To Mount the Tach
PostPosted: Tue Mar 15, 2011 2:58 pm
+1 on the previous suggestion. Do yourself a favor by putting a piece of innertube or electrical tape under the extra-big hose clamp you will be using. That way, when you tire of the tach being in your way, you can remove it and not have to fix the damaged paint on the steering column. Been there...done that many times.
