Cold compression test???
https://www.slantsix.org/forum/viewtopic.php?t=10446
Author:  HyperValiant [ Sat Sep 18, 2004 5:41 pm ]
Post subject:  Cold compression test???
Does anyone how difference there would/should be between a coldcranking compression test and hot cranking compression test?
Thanks
HyperValiant
Author:  Dart270 [ Sun Sep 19, 2004 12:12 pm ]
Cold test might be less consistent between cylinders and read lower than a hot test. No oil on the cyl walls can make the seal worse unless they rings/cyl finish is perfect.
Author:  stinky mctinkerpants [ Thu Sep 23, 2004 10:12 pm ]
hot means operating temp of the motor (its been running for 10 or more minutes) cold is room temp. be careful doing a hot because the motor wants to run and ITS HOT
