| Slant Six Forum https://www.slantsix.org/forum/ |
| Harmonic Ballancer Compatability? https://www.slantsix.org/forum/viewtopic.php?t=10503 |
| Author: | jaweimer [ Sun Sep 26, 2004 7:29 pm ] |
| Post subject: | Harmonic Ballancer Compatability? |
Ok I have a 1971 198 block that we are rebuilding and when we pulled off the harmonic ballancer and cleaned it we noticed that it has a crack running through it and needs replaced. With a junkyard being the only viable (low cost) way to get one is it possible to grab an harmonic ballancer out of any /6? The original motor has factory AC on it if that matters in determining a match. Looking to put this motor back in the car asap, everything is done except for this surprise crack. Thanks for any help and info you may have. |
| Author: | DusterIdiot [ Sun Sep 26, 2004 7:38 pm ] |
| Post subject: | Any 70+ engine... |
You need the balancer off any /6 from 1970+ (you might be able to use one from a 68-69, just look at where the timing tab is placed on the timing chain cover, there are only 2 styles where the TDC notch lies. Make sure to check the rubber on the balancer it can be in bad shape also.... I'd just buy a reconditioned one from Damper Doctors/Damper Dudes in Calif. so I wouldn't have to worry about it on a rebuilt engine. -D.Idiot |
