| Slant Six Forum https://www.slantsix.org/forum/ |
| 1bbl carb jetting https://www.slantsix.org/forum/viewtopic.php?t=10567 |
| Author: | 65dart [ Tue Oct 05, 2004 7:17 am ] |
| Post subject: | 1bbl carb jetting |
My dart has the one bbl carter carb which always worked great at sea level. Now i'm in el paso at 5000 feet and i've lost power and mileage. Can i change the jets in the carb to restore my car and if so what size(s) are reccommended. Thanks. |
| Author: | Guest [ Tue Oct 05, 2004 7:58 am ] |
I would be very interested in hearing what anyone has done for this problem as well. My new 68 Dart is from california, around sea level. I just got it home to colorado,, around 5500ft. and the car seems sluggish, and i'm sure needs jetted down a couple sizes. Mine is also the holly one barrel. Anyone know what size jets were stock one these cars/carbs ? And wheres the best place to get some smaller jets ? Thanks |
| Author: | Doctor Dodge [ Tue Oct 05, 2004 8:28 am ] |
The Holley carb is easy to rejet, all you need is the float bowl gasket and a screw driver. (and the correct jet!) Finding the correct jet size for your conbination is always the challenge, for what you have discribed, I would say a #54-55 jet would be about right. Thr Carter BBS 1 bbl carbs are more of a challenge because these have a floor jet and a step-up rod which are hard to find these days. I usually work with the step-up rod size alone unless the WOT is way rich. Sometimes you can get the BBS to lean-out just by getting the step-up rod to drop down into the floor jet a little more. Take the top off the carb. and measure the diameter of the step-up rod and the floor jet hole. Also look at the ID numbers stamped on the side of the floor jet. (write this information down) Look at the "hook" at the top of the step-up rod and bend it upward, so the rod can drop deeper into the floor jet. You can also bend the mounting tab on the step-up piston downward, to drop the rod. Test drive the car to see if that helps. If still too rich, go on the hunt for the bigger step-up rod or smaller floor jet. DD |
| Author: | MileHighDart [ Tue Oct 05, 2004 9:17 am ] |
Thanks Doctor Dodge ! I'll try to find a few jets today and i'll post my results ! |
