| Slant Six Forum https://www.slantsix.org/forum/ |
| Another valve spring height question... https://www.slantsix.org/forum/viewtopic.php?t=10828 |
| Author: | Guest [ Sat Nov 06, 2004 7:45 am ] |
| Post subject: | Another valve spring height question... |
I have a set of clifford springs, the book says one is taller? which one is for the intake?? the ones i have look all the same height?!? what do I do? thanks again any way to tell i dont have a mic |
| Author: | Guest [ Sat Nov 06, 2004 9:16 am ] |
bump anyone please |
| Author: | Guest [ Sat Nov 06, 2004 10:45 am ] |
can anyone clue me in beforei ininstall and wipe my new cam out |
| Author: | kesteb [ Sat Nov 06, 2004 3:31 pm ] |
Have you asked Clifford? They should be able to tell you which spring goes where. |
| Author: | Doctor Dodge [ Sun Nov 07, 2004 3:06 am ] |
It sounds like the set of springs you have are all the same and install at the same "installed height" on each type of valve. Were there any instructions with the springs? What cam do you have? DD |
| Author: | Guest [ Sat Nov 13, 2004 2:54 am ] |
no instructions its the clifford 280 dur. .467 lift |
