anyone want to ball park it?
https://www.slantsix.org/forum/viewtopic.php?t=10894
Author:  slantsickniss [ Sat Nov 13, 2004 7:25 am ]
Post subject:  anyone want to ball park it?
if i take .75 mill off the head and use fel pro head gasket ballpark wise where would my compression be with stock pistons???
Author:  GTS225 [ Sat Nov 13, 2004 12:27 pm ]
Ummmmmm.....do you REALLY mean ".75" ? Keep in mind, .75 is 750/1000's, or 3/4". You won't have anything left for a combustion chamber, it will have cut off all of the gasket surface, and for damn sure, the valves will hit the pistons.
Roger
Author:  Guest [ Sat Nov 13, 2004 2:10 pm ]
uuuuummmmm i meant 75 thousands
thanx
Author:  70valiant [ Sat Nov 13, 2004 2:47 pm ]
75 thousandths or 0.075" with a thick felpro should get you around 9-1 Compression ratio.
I took 0.100" off my head and am cranking 150-160psi
Author:  Guest [ Sat Nov 13, 2004 3:39 pm ]
thanks!
thats what im lookin for..
im diggin the valiant,,,sweet
