It is currently Tue May 05, 2026 7:57 pm
PostPosted: Sat Nov 13, 2004 7:25 am
if i take .75 mill off the head and use fel pro head gasket ballpark wise where would my compression be with stock pistons???
PostPosted: Sat Nov 13, 2004 12:27 pm
Car Model: '23 T-bucket
Ummmmmm.....do you REALLY mean ".75" ? Keep in mind, .75 is 750/1000's, or 3/4". You won't have anything left for a combustion chamber, it will have cut off all of the gasket surface, and for damn sure, the valves will hit the pistons.
Roger
PostPosted: Sat Nov 13, 2004 2:10 pm
uuuuummmmm i meant 75 thousands
thanx
PostPosted: Sat Nov 13, 2004 2:47 pm
75 thousandths or 0.075" with a thick felpro should get you around 9-1 Compression ratio.
I took 0.100" off my head and am cranking 150-160psi
PostPosted: Sat Nov 13, 2004 3:39 pm
thanks!
thats what im lookin for..
im diggin the valiant,,,sweet
