| Slant Six Forum https://www.slantsix.org/forum/ |
| turn signal changing tips on a 65 ?? HELP! https://www.slantsix.org/forum/viewtopic.php?t=11671 |
| Author: | 65wggnguy [ Tue Feb 08, 2005 8:57 am ] |
| Post subject: | turn signal changing tips on a 65 ?? HELP! |
Hello I was wondering if anyone has any tips on changing a turn signal mechanism on a 65 Valiant. I just got a new one fro mfreddrick dodge and was attepting changing my broken one last night and had no luck after 4 hours. I have changed a couple before, however have forgotten on the trick that I used, PLEASE HELP as I am not able to drive to work THANX |
| Author: | SlantSixDan [ Tue Feb 08, 2005 1:10 pm ] |
What "mechanism" is it that you're trying to replace? Just the turn signal cam, or the entire switch? |
| Author: | Guest [ Tue Feb 08, 2005 2:00 pm ] |
It is the entire switch. I have figured out how though. I grouped the wires in 2 and feed a piece of mechanics wire down then pulled 1 group thru then the other. The problem that I am now dealing with is the new turn signal switch which I got from freddick dodge, is that it is larger than the original one so I have spent the last 2 hours with my dremel brinding out the inside of my column where the cam hits the inside of the column when it turns > AAAAAHHHHHHHHHHHHHHH next time I will try JUST REPLACING the cam. |
| Author: | Chuck [ Thu Feb 24, 2005 5:08 pm ] |
I have cams for the '64 style switch if anyone needs them. I'm not sure how late they can be used. |
| Author: | SlantSixDan [ Thu Feb 24, 2005 5:31 pm ] |
The '64-style switch is '64 through '68, but can be used as far back as '62. The difference between the '62-'63 and '64-'68 switch is the style of terminals on the ends of the wires. |
