| Slant Six Forum https://www.slantsix.org/forum/ |
| valve question???? https://www.slantsix.org/forum/viewtopic.php?t=11730 |
| Author: | 1speedfreak [ Sun Feb 13, 2005 6:58 am ] |
| Post subject: | valve question???? |
How big of a valve (exsaust and intake) can be put in a 1971 225 head,thanks,,,speedfreak. |
| Author: | Guest [ Sat Feb 26, 2005 7:30 am ] |
WOW,,,no one????will smallblock valves from a mopar fit???help please,thanks,,,speedfreak. |
| Author: | GunPilot [ Sat Feb 26, 2005 10:20 am ] |
It's been covered many times throughout the forum. Do a search on 'valve size' and you'll get about 12 pages. |
| Author: | Guest [ Sun Feb 27, 2005 6:35 am ] |
well I tried valve size and wording it deferent ways and it told me no matches,this happened on other search topics with the same results,whats up with that? |
| Author: | Rust collector [ Sun Feb 27, 2005 12:11 pm ] |
Try big valves, and ford 300 valves... |
| Author: | Slantenstein [ Sun Feb 27, 2005 6:18 pm ] |
Try searching under "over sized valves" - Good Luck! |
| Author: | GunPilot [ Sun Feb 27, 2005 6:46 pm ] |
http://www.slantsix.org/forum/viewtopic ... valve+size http://www.slantsix.org/forum/viewtopic ... valve+size http://www.slantsix.org/forum/viewtopic ... valve+size http://www.slantsix.org/forum/viewtopic ... valve+size These were found using a search criteria of 'valve size' in the message field. |
| Author: | sandy in BC [ Sun Feb 27, 2005 7:39 pm ] |
I put 1.72 and 1.50 SBC valves in my head. It is a definite advantage to Sweep the chambers around the valves for flow. The bowls need to be enlarged to match the valves. |
| Author: | Guest [ Mon Feb 28, 2005 6:32 am ] |
Everyone,thanks allot,just what I was looking for,i've played around with 318,340,360,but this is the first time for a 225 or any 6cyl,its all new to me,thanks again,,,speedfreak. |
