| Slant Six Forum https://www.slantsix.org/forum/ |
| Converting to auto trans-how to wire backup lights. https://www.slantsix.org/forum/viewtopic.php?t=11739 |
| Author: | HyperValiant [ Sun Feb 13, 2005 8:49 pm ] |
| Post subject: | Converting to auto trans-how to wire backup lights. |
I just bought a 69 Valiant 4 dr for my daughter and was factory 3spd(it came without a an engine or trans)and plan on using the 225 and 904 from a 75 Duster. What I need to know is how do I keep the backup lights and the park/neutral safety start feature? Can I just use the trans harness from the Duster? Any help is much appreciated. Thanks HyperValiant |
| Author: | Doctor Dodge [ Sun Feb 13, 2005 9:08 pm ] |
The 75 904 should have a 3 pin safety switch, the center pin is for the safety lock-out and the outer pins are for the reverse lights. Pull the plug and wires from the donor car and splice them into your 69. DD |
| Author: | HyperValiant [ Mon Feb 14, 2005 7:03 pm ] |
Thanks Doug,I hope to get this car home in a couple of weeks and get some plans laid out so my daughter and can start on it this coming winter. HyperValiant |
| Author: | 6boy [ Sun Feb 20, 2005 4:25 pm ] |
my 63 dart 270 has stainless covers over the sqaure cut outs where the back up lights would be. I found a 63 GT with the back up lights and lenses. If I get em how do I wire them up to work?? |
