2b to 1b adapter?
https://www.slantsix.org/forum/viewtopic.php?t=11839
Author:  gagolddust [ Mon Feb 21, 2005 4:02 pm ]
Post subject:  2b to 1b adapter?
do they make an adapter to go from a 2 barrel carb to a 1 barrel?
Author:  Craig [ Mon Feb 21, 2005 5:04 pm ]
Someone must.
One of these days I'll make a batch on the CNC at work. Who's got a good pattern?
Author:  hoosierdodge225 [ Mon Feb 21, 2005 5:28 pm ]
Would it not be possible to take the adapter for a 1bbl to 2 bbl and flip it over? I am going back to a one barrel until I can find time to put my super manifold on. I didn't notice any significant change with the adapter and bbd carb. A Hope it gets better with the super setup intake.
Author:  Dustenn89 [ Mon Feb 21, 2005 5:37 pm ]
a question on what u have said. Is it possible to take a 1bbl manifold and use a 2bbl carb. maybe a dumb question but i havent experienced it yet.
Author:  Pierre [ Mon Feb 21, 2005 5:51 pm ]
Dusten, sure, its been done before. Check out www.prolinefuel.com he has the 1 to 2 bbl adapter. I think its availible from your typical auto store as well.
You can flip the same adapter over if you want to go the other direction.
Hoosier I bet you will feel a little difference when using a true supersix intake because the 1 barrel manifold is probably restricting flow of the bigger carb.
Author:  Dennis Weaver [ Mon Feb 21, 2005 5:52 pm ]
...why go to all that trouble when two-barrel intakes are readily available? It won't flow worth a crap.
D/W
Author:  moparfiend [ Tue Feb 22, 2005 5:01 am ]
i used the proline adapter to put a holley 5200 on my 1bbl intake. noticeable performance increase and mileage went from 13mpg to 19 mpg. as far as i'm concerned flow is fine and i couldn't be more pleased with the results and it only took about a half hour.
my 2 cents
Author:  Wesola78 [ Thu Feb 24, 2005 10:02 am ]
Unfortunately, ProLine Fuel is not doing business at this time. When/If he does start doing business again, I would highly recommend him. Chris from ProLine Fuel is a great guy to do business with.
