Suntune and Sunpro Tachometers
https://www.slantsix.org/forum/viewtopic.php?t=11893
Page 1 of 1
Author:  mrhite65 [ Wed Feb 23, 2005 11:49 am ]
Post subject:  Suntune and Sunpro Tachometers
I found a suntune tach at a swap meet. I went to the sunpro site and found info on installing the tach. All the wires are thier, but the difference in the wires are that I have a green wire and they have a white wire. Would these two wires be for the same hook-up?
Also I plan on doing the Hei swap and was wondering if the tach would need to change from being hooked up to the coil to something else?
Thanks!
Author:  spconnor [ Wed Feb 23, 2005 5:36 pm ]
Green goes to your coil (negative). The white wire is for illumination, I sauldered that to the light switch under the dash.
Author:  mrhite65 [ Wed Feb 23, 2005 8:03 pm ]
I don't have the white wire. I have a green one. Is the green one for the lights?
Author:  spconnor [ Wed Feb 23, 2005 10:39 pm ]
Is it an illuminated tach? What color wires are coming out the back of it? Green should go to negative hook-up on your coil. As for the HEI swap im not sure :? ... maybe someone else can help?
Author:  mrhite65 [ Fri Feb 25, 2005 11:25 am ]
Red, Black, Blue, Green. Those are the cpolors of wires I have.
Author:  stimpy [ Fri Feb 25, 2005 3:37 pm ]
Red-power
Black-ground
Blue-lights
Green-coil
The Green wire would still go to the negative coil terminal on HEI.
Author:  mrhite65 [ Fri Feb 25, 2005 8:13 pm ]
OK! Thanks!
