Turn signal assemby
https://www.slantsix.org/forum/viewtopic.php?t=11900
Author:  CurtM [ Wed Feb 23, 2005 10:31 pm ]
Post subject:  Turn signal assemby
1964 Dart: Does anyone know vendors and part# for this item? Also chassis manual and wiring diagrams for same year? Thank You in advance!!
Author:  Jon Dahlberg [ Thu Feb 24, 2005 4:42 pm ]
Are you talking about the turn signal cam in the steering column? I replaced the one in my old 73 Fury a few years ago, I used Murray Park for the assembly....His ads are all over Mopar Collector's Guide. I don't know if he stocks Darts...but he had one for my Fury, and I got prompt service. His number is 419-448-0293. He's out of Tiffin, Ohio.
Author:  SlantSixDan [ Thu Feb 24, 2005 5:30 pm ]
Factory Service Manual for '64 Dodge and Dart is an easy-to-find item; pick up a copy of Hemmings Motor News and make half a dozen phone calls and you'll find one for under $45. Or do an Ebay search, they show up all the time there.
What do you mean by "turn signal assembly"?
Author:  CurtM [ Sat Feb 26, 2005 9:38 am ]
I need a new switch. The one in my Dart is completely worn out.The little moving contacts have most of the copper worn off causing my right rear breaklight to either stay on or not work at all. I cleaned the old switch and contacts and it worked for a day or so then the same problem. After looking at the contacts that is when I discovered the worn copper.I have contacted several local electrical specialists in my area (Central Coast,Ca) and they have no resourses for the assembly.
Author:  SlantSixDan [ Sat Feb 26, 2005 9:49 am ]
I've got new switches in stock.
Author:  CurtM [ Sun Feb 27, 2005 7:04 am ]
Thank you very much!!Yesterday someone told me of a dealer Called 6-pack Jack, he had the part for $286.00 yow.your help is appreciated.
