It is currently Sun May 17, 2026 3:08 pm
 Post subject: One barrel to two barrel
PostPosted: Fri Feb 25, 2005 12:35 pm
I found a one bbl to a holley two bbl adapter. Would this even run right? Would the flow even be worth the conversion?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Fri Feb 25, 2005 1:08 pm
i did the holley 5200 conversion using an adapter and my existing 1 bbl intake. to me i have no complaints. 40% mpg increase and much better performance and it only took a half hour. best bolt on around as far as i'm concerned.
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Fri Feb 25, 2005 2:33 pm
I think it would be worth it, but not with a big holley, maybe the 350cfm...
If you find a weber, that should be closer to "right" for a stock slant.
But that is just my opinion.
I have used a weber 38-38 on a 2bbl intake and that worked fine, but I dont know how a bigger carb would react to the step down into the manifold, with an adapter.
PostPosted: Fri Feb 25, 2005 2:43 pm
Messing with adaptors is counterproductive. 2bbl intakes are easily available. If the job's worth doing, it's worth doing right.
PostPosted: Fri Feb 25, 2005 2:59 pm
But there are a few people out there with the weber/holley 32-36, and they are happy.
So it can not be too bad.
PostPosted: Fri Feb 25, 2005 3:02 pm
And only if you have a good 2bbl carb to install to replace a worn out 1bbl.
I "super sixed" my truck, but it felt like a backstep since my 2bbl carb was more worn out than the 1bbl I was replacing.
It's a half step in the right direction but not worthwhile step for every situation. Better to buy a new 2bbl and an adapter than just a 1bbl replacement carb.
1980 Aspen 225 super six
The point is, it's silly to buy nifty new running shoes if, before you put them on, you deliberately drop a bowling ball on one of your feet. You'll still have nifty running shoes, and you might even still be able to run -- maybe even fast enough to satisfy yourself -- but you won't be running as fast as you could if you hadn't dropped the bowling ball on your foot.
Likewise, people manage to make the adaptor kludge work. But it's silly and pointless and sabotages the upgrade. 2bbl intakes are easily available and a much better option.
PostPosted: Fri Feb 25, 2005 3:04 pm
I don't agree. Money spent on the adaptor could better be spent on the correct manifold for the carburetor. But, each to his own.
PostPosted: Fri Feb 25, 2005 4:21 pm
Im with Dan on this one. If you want a 2 barrel carb get a manifold to match. There are far more decent 2 barrel manifolds out there than decent 2 barrel carbs.
My personal "value" favourite is the diecast aluminum Super6 manifold. Many people are afraid they leak so they seem to be cheap or free. (mine was free). All that is required is a simple leak test to feel confident.
http://www.slantsix.org/articles/supersix/article.htm
PostPosted: Fri Feb 25, 2005 4:53 pm
STOP THE PRESSES!!!
D/W ;)
If it ain't broke, fix it!
PostPosted: Fri Feb 25, 2005 8:20 pm
Thanks for the responces!
PostPosted: Sat Feb 26, 2005 12:26 am
True, adapters aren't the "right way", but I've used them temporarily on V8's with satisfactory results. If you don't have another manifold on hand or you don't want to mess with the stock ones right away (since they're a PITA), I would say go for it.
Just check for hood clearance and adjust the linkage if you need to. :)
PostPosted: Sat Feb 26, 2005 4:47 am
Sure, I agree too, but I dont think it is a waste/ a bad thing either.
It may not be the best way, but anything better than stock, is an upgrade...
I wish I had a 1bbl intake...
PostPosted: Sat Feb 26, 2005 4:55 am
It would be the wide based Holley with 350 cfm's. On a single bbl. intake.
PostPosted: Sat Feb 26, 2005 5:21 am
I guess I would give it a try, but I think that is too much carb for a small hole.
You might get issues with it.
Users browsing this forum: Google [Bot], morsim and 6 guests
