| Slant Six Forum https://www.slantsix.org/forum/ |
| blown head gasket https://www.slantsix.org/forum/viewtopic.php?t=11950 |
| Author: | vic vickery [ Sat Feb 26, 2005 6:43 am ] |
| Post subject: | blown head gasket |
my slant is blowing water out the exhaust pipe....why do I not see water in the oil or oil in the water....also compression 120 t0 130 all cylinders...I'll be taking the head off tomorrow....anything in particular I should be looking for....thanks...vic |
| Author: | Guest [ Sat Feb 26, 2005 7:55 am ] |
Same situation I was in last summer. Look at the block to see if and water jackets are blown out, you may just have a blow out inbetwen cylinders. There was a hole where mine blew in a water jacket. It put a hole through the top of the block, through the gasket,through the head...not good. It's a 15$ fix though |
| Author: | vic vickery [ Sun Feb 27, 2005 12:39 pm ] |
| Post subject: | vic vickery |
I'm assuming you just mean replace the head gasket....vic |
