| Slant Six Forum https://www.slantsix.org/forum/ |
| Lifting a slant six https://www.slantsix.org/forum/viewtopic.php?t=12367 |
| Author: | Acuda4me@AOL.com [ Fri Mar 25, 2005 12:26 pm ] |
| Post subject: | Lifting a slant six |
Speaking of dumb questions, I have to pick up a slant six from a friend's garage and have no idea if he has any chain or bolts attached to the engine. What size bolts do you use and where do you normally attach them when lifting an engine? Jeff Voth |
| Author: | SlantSixDan [ Fri Mar 25, 2005 12:56 pm ] |
there are two heavily-gussetted holes on the top of the cylinder head, between the valve cover and the manifold surface. Use those. (Not a dumb question, btw) |
| Author: | Acuda4me@AOL.com [ Fri Mar 25, 2005 1:31 pm ] |
Thanks. What size bolts? |
| Author: | SlantSixDan [ Fri Mar 25, 2005 4:41 pm ] |
Uhm...I don't know, off hand! Someone wanna go measure? |
| Author: | hantayo13 [ Fri Mar 25, 2005 6:59 pm ] |
3/8 SAE about 1&1/2 lenght shold work just fine |
| Author: | Doctor Dodge [ Sat Mar 26, 2005 11:27 am ] |
Quote: 3/8 SAE about 1&1/2 lenght shold work just fine
3/8-16 unc thread size, most of thes fasteners have the 9/16 hex head.DD |
| Author: | NewLancerMan [ Sat Mar 26, 2005 12:10 pm ] |
1.5" might be a bit long--I had some sticking out on that size. Just in case, check the front bolt. My 62 had a smaller thread diameter on that front one so I had to use chain on the intake/exhuast manifold to lift it. MJ |
| Author: | dart63 [ Sun Mar 27, 2005 8:28 pm ] |
Carefull when using the front hole near the water outlet.........too long of a bolt and you will find yourself tapped into the water jacket playing "Little Dutch boy" |
| Author: | NewLancerMan [ Mon Mar 28, 2005 5:17 am ] |
hmm i'll have to check on that one. This hole was located near the middle of the block. I'll take a pic when im there later this week. My other 62 engine had two of the same size holes...go figure. And heck..i'm Dutch so my finger should work indefinitely =) MJ |
| Author: | 74360scamp [ Tue Mar 29, 2005 7:29 pm ] |
Yes, the "front" hole on my 74 225 is actually towards the middle of the block. Both of my bolts had parts attached with them. 9/16 was the head size of both of the bolts on mine. dave |
