It is currently Sat Jan 03, 2026 1:55 am
PostPosted: Thu Jun 02, 2005 10:33 am
Car Model: 1962 Lancer 770
Hey all,
So I am looking at my block wondering if there is any way to clean it without hot-tanking since I'm not planning on disturbing the crank or any of the main bearings. Should I try degreaser and pressure washing? Or not worry about it? Or run engine soup concoction through it once installed?
What tricks have you guys used?
MJ
PostPosted: Thu Jun 02, 2005 11:34 am
How dirty is it inside? Post some pics, or at least a description. Your best option may be "do nothing".
PostPosted: Fri Jun 03, 2005 6:40 am
Dirty would be just black and greasy insides. Its just a layer of crud. I dont have any pics handy unforntunately. I cleaned out the bottom fo the oil pan when I swapped it over. I just wanted to be sure short of hot-tanking it that I didn't need to do anything more to it. I figured an oil change every 1000 miles for a while would be the best.
MJ
PostPosted: Fri Jun 03, 2005 7:24 pm
:?: Is this an in-frame youre doing?
Main bearings arent that expensive, if you hot-tank the block and crank, and plastigage the bearings you should be fine, it's not all that bad...
PostPosted: Fri Jun 03, 2005 7:43 pm
nah its a time-frame issue. I'm moving next week ;-) I just ended up power washing it, and its actually in great shape. no worries. pulled the cam just so I knew how to do it, lubed it, degreed it for practice -- they have a cam wheel and dial indicator so why not try?! I'll take some pics tomorrow.
MJ
Users browsing this forum: Bing [Bot] and 12 guests
