It is currently Tue Nov 10, 2026 12:20 pm
 Post subject: Full Race
PostPosted: Thu Aug 11, 2005 5:30 pm
I'm running a 225, Weiand 4 intake, Clifford Headers, MP Cam, MSD, 650 Holley, Ford Valves/ pocket ported. W/904 3500 stall and 8.25 / 4:10 posi. Its in a 63 Dart. With this very well used combo I ran 15:40 with a track temp of 153 deg. (Tulsa gets hot) It's time for a overhaul, after this site I'm thinking 198 rods etc. A little NOS and more cam. What are the big dogs using? Pistons, cam etc. I'm also thinking a s/6 in a 1500 lbs roadster for the HAMB drags would be a killer anyone use one in a altered? :twisted:
PostPosted: Thu Aug 11, 2005 7:44 pm
SSRN National Champion
The big dogs are running turbos and superchargers is that big enuff the other folks are running built engines that are running fast how fast do you want to go. Ron Parker
Hell Hath No Wrath Than A Possum Scorned
PostPosted: Thu Aug 11, 2005 10:17 pm
If you want to build a serious race motor with any amount of juice, throw the 198 rods in the junk and get a set of steel rods. Forged pistons will be in order too.
I am running 198 rods and KB hyper 2.2 turbo pistons. I have been spraying a 150 shot, but I am really living on the edge. 198 rods kinda like to bend.
Good motor with a 150 shot in a light roadster and the 9's are yours easy. There used to be a Slant roadster down in Georgia or Alabama, but IIRC he put a small block in it. :cry:
PostPosted: Fri Aug 12, 2005 3:16 pm
Thanks for the replys, I was thinking 12's in the Dart and maybe 10's in a roadster. Custom steel rods and turbo's would be out of my price range at the present time. Aren't the 198 and 225 rods both forgings? And with ARP's and resize enough to handle a 150 shot in a purpose built car. I'm not looking for a street car or a bracket racer something to race at old time drag events.
PostPosted: Fri Aug 12, 2005 6:38 pm
Better check the rules for the old time drags. Down here in Florida, it's "NO NITROUS". The promoters say it wan't in much use, back in those days. Blowers and turbos are ok.
PostPosted: Thu Aug 18, 2005 6:30 pm
Call the Cox Bros and get the NEW rods & pistons You need for your build up. Head gaskets and advice you need. You can run 12's or even 11's on the stock stuff but it may be time to step up.
Will
PostPosted: Fri Aug 19, 2005 3:16 am
What rods & pistons are Cox Bros selling? And in what price range? Yes, I could call and ask, but with my english...
PostPosted: Fri Aug 19, 2005 4:13 am
If you plan to run a bottle then you will need the high buck piston/rod combo. If you go the boosted route 198 rods and the 2.2 turbo piston will last and will save some $$$. We have not had a problem with either and the only time we did it was the tuners(me) fault for leaning it out too far. If you are not going to be running on the ragged edge you can put in a safe tune up and go fo it....
Tom
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
 Post subject: Slant Altered
PostPosted: Fri Aug 19, 2005 7:01 am
The HAMB drags will be mostly flathead V8s and a few stovebolts, right? It would be interesting to see what a healthy slant could do in a field like that.
Here's a link to a guy that ran a slant 6 roadster, back when: http://www3.sympatico.ca/big-d/pics.htm
Ran in turboed and NA form.
Last one out , turn off the light
PostPosted: Fri Aug 19, 2005 6:06 pm
Lots of good info. The dart I own won Gas coupe class at the HAMB drags last year. The HAMB drags are a gas, almost anything you could think of runs. Real low key and laid back.
