It is currently Mon Oct 26, 2026 8:29 am
PostPosted: Thu Dec 15, 2005 11:31 am
I've decided to do a mild performance build on the old slant, and I'd like to know what you guys think about my choices.
170 144 SI valves
mild head port and shaved .100
Dutra Duals
Offy 2x1 intake (I know a 4bbl is better, but I really dig the look)
comp 264 cam
I've already got a pertronix kit installed.
Any suggestions or comments would be appreciated.
thanks
-josh
64 Dart 170 /6
PostPosted: Thu Dec 15, 2005 12:52 pm
sounds pretty good, if you want a little performance boost. and yeah i think the 2x1 looks cool, but i was going to go 4bbl :P
Cuda Progress :D
The dart as it sits now :(
PostPosted: Fri Dec 16, 2005 4:49 am
Read through the Block Prep article for some info.
http://www.slantsix.org/articles/dutra- ... blocks.htm
I would invest in a good timing gear and chain set. Degree the cam.
A case hardened oil pump gear would also be a good piece of "insurance".
PostPosted: Fri Dec 16, 2005 6:45 am
Thanks Doc. That is a superb article. Where can I get said oil pump gear and how much should I add to my budget for it?
-josh
64 Dart 170 /6
PostPosted: Fri Dec 16, 2005 7:33 am
Sounds like a plan to me!
What carbs will you mount on that Offy? BBS's?
PostPosted: Fri Dec 16, 2005 7:38 am
Yup, carter BBS's. They're what I've always had, so I'm more comfortable with them.
64 Dart 170 /6
