It is currently Tue Dec 30, 2025 3:39 am
 Post subject: Engine Build
PostPosted: Sun Dec 25, 2005 3:04 am
I have a 74 Duster with a 225 I have to rebuild the entire motor, have to start fresh, I was wondering what performance mods I should do. I would like to keep the cost at about 2,500 considering the fact I have to put and entirely new steering system in, if any of you know if I could buy a complete kit somewhere online it would really help me out.
 Post subject: lots of options
PostPosted: Sun Dec 25, 2005 7:59 am
Car Model: 1974 W100; 72 Dart
i don't know where you are located, but i built a 225 for A LOT less than $2500! if you are going mostly stock, the rebuild can be done very reaonably, but (as always) the faster you want to go the more it costs.
i took my block to a local machine shop had it bored, bought pistons, a crank kit and gaskets all for about $200. oil pump and timing chain from a local auto parts store for $80.
went through some trouble with the head...the initial head i did was $370 (back cut valves, pocket port, gasket match) but it ended up needing to be trashed. soooo, $35 at the junkyard and $104 at the machine shop later i had a rebuilt stocker head.
Erson cam from summit for $127.
so, machining parts and all under $600. plus of course engine paint, etc etc.
if you are not looking for a lot elbow grease on your part: a short block might be in order. i don't know what they go for, but they are still available from most engine builders. (there is a long block on ebay right now for $1200 i believe)
the only complete kit i know of offhand is clifford's kit for about $800.
http://cgi.ebay.com/ebaymotors/Engine-r ... enameZWDVW
that is a link to a rering kit on ebay for like $50. you could get the other stuff the way i did. hope this helps a little. we could get a LOT more detailed if we knew more of what kind of build you were after.
sb
PostPosted: Sun Dec 25, 2005 11:18 am
http://www.flatlanderracing.com/rebuildkitschrys.html
$189.00 for an "Overhaul Kit" here is their description:
Overhaul Kits include: Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Thrust Washers, Aux Shaft Bearings (if applicable), and Valley Pan (if applicable).
For $375.00 you get the "Master Engine Kit":
Master Engine Kits include: Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Oil Pump, Freeze Plugs, Camshaft, Lifters, Pre-lube, and Timing Set, and Valley Pan (if applicable).
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
