| Slant Six Forum https://www.slantsix.org/forum/ |
| Starter dust cover https://www.slantsix.org/forum/viewtopic.php?t=15516 |
| Author: | Pierre [ Sun Dec 25, 2005 10:39 pm ] |
| Post subject: | Starter dust cover |
For a slant with 904, was there ever a shield around the starter? I know there was a dust shield around the bottom for the torque converter, but I never remember removing one from around the starter. Right now, using a mini starter, theres a gap between bottom of starter and block, exposing the torque converter. Its not a huge deal, I figure there probably was a plate there that was previously removed. Will one of http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4599082679 these meant for a big block work? |
| Author: | SlantSixDan [ Sun Dec 25, 2005 10:45 pm ] |
| Post subject: | Re: Starter dust cover |
Quote: For a slant with 904, was there ever a shield around the starter?
Starter seal, the factory called it. Always. One per car.Quote: Right now, using a mini starter, theres a gap between bottom of starter and block, exposing the torque converter.
Reinstall the seal...!Quote: Will one of http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4599082679 these meant for a big block work?
Yep!Can also grab one out of the wrecking yard, probably free of charge. |
| Author: | Pierre [ Sun Dec 25, 2005 11:31 pm ] |
Thanks for the info Dan. I couldn't find any refernece to it in the FSM, and in the parts book they show a one piece dust cover between block and bellhousing for a manual but didn't show an auto picture. Then again I didn't spend too much time but quickly thumbed through it. Time to buy it on cd, big bulky books get annoying. |
| Author: | andyf [ Tue Dec 27, 2005 8:57 am ] |
If you are using a mini-starter then the factory shield will leave a gap. Mancini Racing now carries a shield that is designed to work with the mini-starter. http://store.yahoo.com/chucker54/stststsh.html |
