ac hose
https://www.slantsix.org/forum/viewtopic.php?t=16034
Author:  Dustenn89 [ Sat Feb 04, 2006 2:46 pm ]
Post subject:  ac hose
anyone know where i can get or have made an ac hose than runs across the valve cover from the compress to the firewall. i was putting freon in mine and the next morning i came out and it had ripped a hole in it.
any help appreciated
dustin
Author:  SlantSixDan [ Sat Feb 04, 2006 2:55 pm ]
Lots of shops can re-hose A/C lines. Check your local yellow pages.
Is it possible you overcharged the system?
Author:  Dustenn89 [ Sat Feb 04, 2006 2:58 pm ]
no we were real careful of that
but it was the og hose and it had the spiderline cracks all over it so i thought i would try it and see what happened
but she was cold that night
ill try some shops later tomorrow
thanks for the quick response
dustin
Author:  SlantSixDan [ Sat Feb 04, 2006 3:19 pm ]
Try for "barrier hose". If you can't find a shop that'll rehose your lines, post back and we'll get you some recommendations for where you can send your hoses to be reworked.
Author:  64 Convert [ Sat Feb 04, 2006 3:47 pm ]
Here in Texas, it's easy to find shops that make new hoses. However, not all of them stock the fittings you might need. My local NAPA store has the hose and will do the crimping, but the number of fittings they have on hand is limited. We are lucky to have an AC supplier and compressor rebuilder in town and they have a good supply of fittings.
Author:  SlantSixDan [ Sat Feb 04, 2006 4:36 pm ]
The fittings needed for most of the factory A/C systems in our cars are long since NLA.
Author:  Charrlie_S [ Sat Feb 04, 2006 5:14 pm ]
If you need to send the hose out, to get it done, you can send it to me. I have the equipment to repair/rehose, and build new hoses.
