| Slant Six Forum https://www.slantsix.org/forum/ |
| dual field alternator conversion kit https://www.slantsix.org/forum/viewtopic.php?t=16304 |
| Author: | james longhurst [ Fri Feb 24, 2006 7:08 am ] |
| Post subject: | dual field alternator conversion kit |
i'm not sure if anybody has seen this, so i thought i'd post a link. it looks pretty interesting. i know there are cheaper ways to make the swap, but this is new stuff except for the alternator and it appears to be pretty much plug and play. http://www.uscartool.com/ you'll have to select "dual alternator conversion kit" from the menu on the left. -james |
| Author: | SlantSixDan [ Fri Feb 24, 2006 10:38 am ] |
Quote: All new stuff except for the alternator
That's the problem. Remanufactured = junk.
| Author: | phogroian [ Mon Feb 27, 2006 12:42 pm ] |
Some rebuilds last longer than others. It's no big deal- It's a light unit, takes 15 minutes to replace with the right tools, and the ammeter will indicate failure pronto- I say go for it and keep a spare in the trunk- I keep extra hoses, belts, fuel pump, water pump, starter, tools, etc. there anyway. |
| Author: | SlantSixDan [ Mon Feb 27, 2006 9:49 pm ] |
Suit yourself; I use quality parts that probably won't die, rather than dubious and unpredictable ones that probably will, so I don't have to keep a rolling junkyard in my trunk. (That doesn't mean I don't, just that I don't hafta! |
| Author: | Dennis Weaver [ Mon Feb 27, 2006 10:29 pm ] |
...my life is a rolling junkyard! D/W |
| Author: | dakight [ Tue Feb 28, 2006 3:58 am ] |
Quote: ...my life is a rolling junkyard!
You should see my garage! D/W |
| Author: | Dennis Weaver [ Tue Feb 28, 2006 5:24 am ] |
Quote: Quote: ...my life is a rolling junkyard!
You should see my garage! D/W D/W |
| Author: | dakight [ Tue Feb 28, 2006 7:32 am ] |
| Author: | Dennis Weaver [ Tue Feb 28, 2006 8:15 am ] |
Quote: Land must be cheaper, or neighbors more understanding in Georgia.
Maybe a little, but still it's the same all over. That's why I keep all my junk on the move! D/W |
| Author: | 69a100 [ Wed Mar 01, 2006 8:13 am ] |
| Post subject: | Dual Fiels Alts. Conversion |
$149 bucks!!!!!!!!! I did the same thing with j/y parts on my slant more than 3 years ago for less than $40, and still no problems with it. I guess maybe I just got lucky. I'd tell him to go take a dump for that price, but that's just me.[/b] |
| Author: | james longhurst [ Wed Mar 01, 2006 12:05 pm ] |
| Post subject: | Re: Dual Fiels Alts. Conversion |
Quote: $149 bucks!!!!!!!!! I did the same thing with j/y parts on my slant more than 3 years ago for less than $40, and still no problems with it. I guess maybe I just got lucky.
i've done it for free with stuff from a $100 parts car i bought for the disc brakes and lbp axle. like i said there are cheaper ways to do it and you don't have to buy their reman alternator. the real cheap way out is to buy an electronic regulator (standard p/n vr-1000 i think?) that swaps in place of the factory points type and you're there. the second field wire is just a ground, so you're not really gaining anything there. I'd tell him to go take a dump for that price, but that's just me.[/b] the thing that i thought was nice is the wiring is all new and it plugs in. for guys with cars like my '63 valiant this is a real godsend as the wiring is brittle and needs replacing anyway. -james |
| Author: | Dennis Weaver [ Wed Mar 01, 2006 12:52 pm ] |
...it's alwez best doin' it for free! D/W |
