excessive backpressure
https://www.slantsix.org/forum/viewtopic.php?t=17019
Page 1 of 1
Author:  Jeb [ Wed Apr 12, 2006 7:16 am ]
Post subject:  excessive backpressure
Ever since I hoked the two barrel setup on my Duster up to the stock 1-barrel exhaust system I have noticed that my exhasut pipe is EXTREMELY hot, way hotter than it got with the one barrel. The engine is not running lean as my plugs are a nice tan color, not the blistered white they were when I had the 1-barrel setup. Is this heat buildup due to excessive backpressure? I am trying to get up enough money to install a 2 1/4 exhaust system, since you can really that stock exhaust weezing and bellering when you you start up a hill or get on it. Is it going to hurt anything to continue to run the small exhaust pipe until I get my larger exhaust installed. I don't want to burn out any gaskets or have a cracked manifold.
Author:  Dennis Weaver [ Wed Apr 12, 2006 7:44 am ]
Everything will be fine, Jeb. The BBD is simply a more accurate fuel metering device, so you're not wasting as much gas cooling the exhaust stream. :D If it's not spark-knocking or showing other signs of lean-ness (you say the plugs look good), then enjoy your improved gas mileage.
D/W
Author:  robgoudy [ Wed Apr 12, 2006 7:45 am ]
Are you running a cat that has perhaps become clogged or collapsed?
Author:  Dennis Weaver [ Wed Apr 12, 2006 7:46 am ]
...no cataclysmic converter until '75.
D/W
Author:  KBB_of_TMC [ Wed Apr 12, 2006 9:51 am ]
Post subject:  backpressure
To measure the backpressure in my stock '75 /6, I made up a little adaptor plate to the EGR port. I think I saw a max of 5psi & 2psi typically w/ an all stock system, but I can't remember the #s for sure - it's been too many years.
I remember trying to determine if that backpressure was excessive, but finially decided it was OK and that the converter wasn't plugged.
Author:  Jeb [ Wed Apr 12, 2006 9:55 am ]
D/W
Actually my gas mileage has went down since I changed to the two barrel. But I love the extra response too much to take it off.
