| Slant Six Forum https://www.slantsix.org/forum/ |
| Steering wheel crack repair https://www.slantsix.org/forum/viewtopic.php?t=17128 |
| Author: | Otto [ Tue Apr 18, 2006 4:37 pm ] |
| Post subject: | Steering wheel crack repair |
I have a 1966 Dodge Coronet with a nice red, but cracked steering wheel. Do any of you experienced restorers have any suggestions on a good way to repair these cracks? |
| Author: | SlantSixDan [ Tue Apr 18, 2006 4:52 pm ] |
That's a lengthy and fiddly process, but it can be done with epoxy putty such as PC7. You have to grind/file the cracks so they're V-shaped and free of loose plastic chunks, clean the parent plastic thoroughly, apply the putty and shape it, sand/fettle it to final shape, then paint the whole wheel. PC7 can be found at most good hardware or home stores. Eastwood has a Kit and a Book. |
| Author: | 64 Convert [ Tue Apr 18, 2006 5:25 pm ] |
I've used J-B Weld a couple of times and it worked well. After 3 years, it still hasn't cracked or come out. |
| Author: | Jeb [ Tue Apr 18, 2006 6:07 pm ] |
POR-15 makes a steering wheel kit also. |
