Foam wedgies at rear of 63 engine compartment
https://www.slantsix.org/forum/viewtopic.php?t=18515
Author:  sixsignet [ Wed Jul 12, 2006 3:02 pm ]
Post subject:  Foam wedgies at rear of 63 engine compartment
There is a shelf below the battery that goes back behind and under the firewall. The shelf on the passenger side is the same.
On my 63, there are styrofoam wedges wedged in just behind the plane of the firewall.
Are these stock?
What are they for?
Is it OK to remove them?
Author:  65 dartman [ Wed Jul 12, 2006 3:42 pm ]
They're present on all 4 of my 65s as well. IIRC when I parted out a 66 Dart GT, they were there as well.
Author:  dart64rg [ Wed Jul 12, 2006 4:50 pm ]
They are splash shields. If you remove them you will see into the fenderwell, and if you go through a puddle without them, a lot of water will get past them(I wouldn't doubt that a little gets by already, but not enough to worry about).
You could probably fabricate something out of sheet metal that would look better. That is if anybody looks that far down into the engine bay for it to matter.
Author:  Guest [ Thu Jul 13, 2006 5:00 am ]
I was wondering about that myself. Thanks.
