It is currently Fri Apr 24, 2026 4:17 pm
 Post subject: Gauges
PostPosted: Thu Aug 03, 2006 8:34 am
I HAVE A 67' DODGE DART. THE TEMP AND FUEL GAUGE DON'T WORK.. I DON'T KNOW WHAT SEEMS TO BE WRONG WITH IT, CAN ANYONE HELP? OR EMAIL A WIRING DIAGRAM? THANKS.
PostPosted: Thu Aug 03, 2006 9:22 am
First, read and follow the suggestions in this thread.
Then, go read this, and this, and this, and this.
Or, you can simply get a new replacement old-type "instrument cluster voltage regulator" from NAPA or CarQuest.
PostPosted: Thu Aug 03, 2006 11:47 am
wow, that was a lot, that was a huge amount of help though.. thanks, i'll give it a try...
PostPosted: Thu Aug 03, 2006 9:16 pm
MXN002- slantsixdan pointed out to me that I might have some weird grounding issues, but, when I replaced the bulbs in the grille-mounted turns signals on my '71 Dart, the fuel and temp gauges started working again. :shock:
That advice is worth exactly what you paid for it. :D Good luck.
PostPosted: Fri Aug 04, 2006 8:38 am
NO WAY, JUST BY CHANGING THE BULBS? ONE OF MY BLINKERS IS OUT, I'LL DO THAT BEFORE ANYTHING ELSE... THANKS!!
