It is currently Thu Jan 01, 2026 5:41 am
PostPosted: Fri Nov 03, 2006 3:09 pm
Just bought a used Clifford intake. Is the plane that the 4 brl. carb adaptor bolts onto supposed to be at an angle? If this intake was bolted onto the car, the carb would actually be leaning toward the front of the car slightly. Is that normal for this intake?
72 Dart Swinger....One toke over the line
PostPosted: Fri Nov 03, 2006 3:33 pm
The engine when properly mounted will be pointing up slightly in the front, leaving the carburetor level to the ground. This is the same for v-8 manifolds. When sitting on an engine stand the carb mounting looks odd, but when mounted in the car, it will all make sense.
My cars are all gone, my new affliction is my Jeep Cherokee. I have lifted it, put some armor on it, and preparing for new gears and lockers. After that, bumpers, on-board air and a winch.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
