| Slant Six Forum https://www.slantsix.org/forum/ |
| Motor mount bolts https://www.slantsix.org/forum/viewtopic.php?t=20672 |
| Author: | Bren67Cuda904 [ Wed Nov 08, 2006 9:34 pm ] |
| Post subject: | Motor mount bolts |
Does anyone have a spool type motor mount bolt and washer out that can be measured? I don't have any and need to go to hardware to get 2 bolts and 4 washers for my pancake to spool mount conversion. (I changed the K-member) |
| Author: | Bren67Cuda904 [ Thu Nov 09, 2006 7:50 pm ] |
Size? Grade? |
| Author: | Doctor Dodge [ Thu Nov 09, 2006 9:05 pm ] |
1/2 - 13 unc thread bolts, about 4.5 - 5 inches long. Measure the space between the "forks" of the K-frame mounting and then allow another inch or so of bolt length. You should be able to install the bolt, washers & nut through the spool mount and then lower the entire assembly onto the fork notches. DD |
