It is currently Sat Dec 27, 2025 11:52 am
 Post subject: Motor mount bolts
PostPosted: Wed Nov 08, 2006 9:34 pm
Does anyone have a spool type motor mount bolt and washer out that can be measured? I don't have any and need to go to hardware to get 2 bolts and 4 washers for my pancake to spool mount conversion. (I changed the K-member)
PostPosted: Thu Nov 09, 2006 7:50 pm
Size?
Grade?
PostPosted: Thu Nov 09, 2006 9:05 pm
1/2 - 13 unc thread bolts, about 4.5 - 5 inches long.
Measure the space between the "forks" of the K-frame mounting and then allow another inch or so of bolt length.
You should be able to install the bolt, washers & nut through the spool mount and then lower the entire assembly onto the fork notches.
Users browsing this forum: Bing [Bot] and 9 guests
