| Slant Six Forum https://www.slantsix.org/forum/ |
| Oversized Valves to extreme https://www.slantsix.org/forum/viewtopic.php?t=20731 |
| Author: | Bren67Cuda904 [ Mon Nov 13, 2006 5:14 pm ] |
| Post subject: | Oversized Valves to extreme |
Check out this oversized valve that going in. (Exhaust) http://www.renaissanceracing.com/images ... eLarge.JPG http://www.renaissanceracing.com/images ... Large3.JPG |
| Author: | Dart270 [ Tue Nov 14, 2006 5:54 am ] |
Bigger is better, I guess... Lou |
| Author: | Slant Cecil [ Tue Nov 14, 2006 10:37 am ] |
Just one of those is enough to feed the whole motor! |
| Author: | heckshemi [ Tue Nov 14, 2006 11:28 am ] |
You may need to notch the bores. |
| Author: | CStryker [ Tue Nov 14, 2006 5:11 pm ] |
Geeze, is their actually an application on that, or is it just a fun toy? |
| Author: | Jeb [ Tue Nov 14, 2006 5:21 pm ] |
That looks like one of those huge stamps they use at the post office. Kind of sad when your valves are bigger than your pistons. |
| Author: | Wizard [ Tue Nov 14, 2006 5:36 pm ] |
MP headgasket or felpoo on the wall for 2.2/2.5L. Cheers, Wizard |
| Author: | Ron Parker [ Tue Nov 14, 2006 6:38 pm ] |
Looks like a valve out of a large diesel engine say a locomotive. Am i right or not . Thanks Ron Parker It Aint Over Until I Win |
| Author: | Bren67Cuda904 [ Tue Nov 14, 2006 9:00 pm ] |
The valve is from a boat, a very big boat. Military destroyer sized boat. |
| Author: | Eric W [ Tue Nov 14, 2006 9:09 pm ] |
| Post subject: | So? |
.......and this has what to do with slant six's? |
| Author: | argentina-slantsixer [ Wed Nov 15, 2006 3:51 am ] |
| Post subject: | Re: So? |
Quote: .......and this has what to do with slant six's?
pull over son(to protect and to serve) C'mon man, take the day off |
| Author: | Bren67Cuda904 [ Wed Nov 15, 2006 5:36 am ] |
Seeing as that big valve is sitting on top of my Slant 6 cylinder head..... |
| Author: | sandy in BC [ Wed Nov 15, 2006 6:26 am ] |
Not locomotive....at least not Canadian locomotive. They are 10 cyl , 2 stroke , with 2 cranks and 2 pistons per cylinder. The top crank drives the blower. The top crank has a shorter stroke than the bottom. Four of Brens valves would feed a head on a 200HP cylinder. My personal fave: 3000hp V16 twin turbo Mirrlees. 10" bore/10" stroke. Sounds like rock n roll at 330rpm (rev limit) Turbos are 4 ft in diameter. Heads are 4 valve per cylinder. |
| Author: | Joshie225 [ Wed Nov 15, 2006 6:36 am ] |
Shoot, we've only got 1000hp x 2 at work. Cummins V12s, 6.25" bore and stroke makes for 2300 cubes. 4 valve/cylinder too. There is a turbo on each bank bigger than my head. Each turbo has it's own exhaust and a muffler larger than a 55 gallon drum. These are for backup power and spin 1800 RPM and will produce 750kW each, but we only run one up to 80% (600kW) before the 2nd one is automatically started and brought on-line.
| Author: | sandy in BC [ Wed Nov 15, 2006 12:10 pm ] |
![]() Not exactly what I worked on but close. Ours had exposed rocker gear and pushrods. To get reverse you stopped the engine, changed cam timing (pneumatically) and started it in reverse. Direct drive....counter rotating. One fuel pump per cylinder. One of my most memorable moments: Lying in the crankcase (dry sump) while the crank was rolled over by the elctric turning gear. We were checking rod bearings and because I was the slimmest I was elected to do the checking. There is quite a throw on a crank with a 10" stroke.... |
