| Slant Six Forum https://www.slantsix.org/forum/ |
| K-member change, now exhaust touches center link https://www.slantsix.org/forum/viewtopic.php?t=20810 |
| Author: | Bren67Cuda904 [ Mon Nov 20, 2006 7:33 pm ] |
| Post subject: | K-member change, now exhaust touches center link |
I changed out my 67 K-member for the 74 slant-member and now the engine seems to sit a bit lower and the exhaust rubs the center link. Has anyone had this happen or is this known to happen? Its not a big deal for me because I am putting in a new exhaust and will bend around it, but it seems odd that the motor would set lower. Its about 3/4" lower. Lower center of gravity can't be bad. |
| Author: | DusterIdiot [ Mon Nov 20, 2006 8:30 pm ] |
| Post subject: | Motor mount spools... |
If you used a used old set of spool mounts they can sag a bit as the rubber is "well worn in"... -D.Idiot |
