| Slant Six Forum https://www.slantsix.org/forum/ |
| Hyd cams in older engins https://www.slantsix.org/forum/viewtopic.php?t=20848 |
| Author: | gtalley [ Wed Nov 22, 2006 10:52 pm ] |
| Post subject: | Hyd cams in older engins |
Hi all. I'm a new member with a 1985 Dodge truck with a bad engine. I found a good used short block from an older car. A forged crank engine with the same size flange for the flywheel. I would like to put the hyd cam from the 85 into the old engine. What do I need to change? Thanks. |
| Author: | slantzilla [ Thu Nov 23, 2006 9:50 am ] |
| Post subject: | Re: Hyd cams in older engins |
Quote: What do I need to change?
Your mind. Sorry, couldn't resist. There is no advantage to using the juice cam in an older block. |
| Author: | SlantSixDan [ Thu Nov 23, 2006 10:20 am ] |
Slantzilla's right. The solid-lifter cam is better (performance, driveability, MPG, valvetrain dependability), and valve cover removal in a great big truck engine bay is easy...just climb under the hood to adjust the valves! Just swap the replacement engine complete; you'll wind up happier overall. |
| Author: | Ron Parker [ Thu Nov 23, 2006 6:16 pm ] |
Bingo every body is right on this one Thanks Ron Parker It Aint Over Until I Win |
| Author: | gtalley [ Fri Nov 24, 2006 11:09 pm ] |
OK, You have talked me into the solid lifter cam. Now does anyone need a new set of hyd lifters? |
