It is currently Fri Jan 02, 2026 4:12 am
 Post subject: Hyd cams in older engins
PostPosted: Wed Nov 22, 2006 10:52 pm
Hi all. I'm a new member with a 1985 Dodge truck with a bad engine. I found a good used short block from an older car. A forged crank engine with the same size flange for the flywheel. I would like to put the hyd cam from the 85 into the old engine. What do I need to change? Thanks.
Glenn H Talley
PostPosted: Thu Nov 23, 2006 9:50 am
Your mind. :shock:
Sorry, couldn't resist. :D
There is no advantage to using the juice cam in an older block. :?
PostPosted: Thu Nov 23, 2006 10:20 am
Slantzilla's right. The solid-lifter cam is better (performance, driveability, MPG, valvetrain dependability), and valve cover removal in a great big truck engine bay is easy...just climb under the hood to adjust the valves! Just swap the replacement engine complete; you'll wind up happier overall.
PostPosted: Thu Nov 23, 2006 6:16 pm
SSRN National Champion
Bingo every body is right on this one Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Fri Nov 24, 2006 11:09 pm
OK, You have talked me into the solid lifter cam. Now does anyone need a new set of hyd lifters?
Glenn H Talley
