| Slant Six Forum https://www.slantsix.org/forum/ |
| manifold leak https://www.slantsix.org/forum/viewtopic.php?t=20884 |
| Author: | 75dartcustom [ Sun Nov 26, 2006 10:02 am ] |
| Post subject: | manifold leak |
while adjusting my choke today I noticed faint wisps of smoke coming from union where the manifold meets the engine. I shut of the car and upon closer inspection found solid black carbon at the 2, 3, and 4 runners there against the head. I had a rebuilt engine put in my car 6 mos ago and the guy also installed a 2 barrell carb and manifold, ie I don't have any experience with manifolds. can i just tighten the manifold at the 2, 3 and 4 spots? what would be the best way for me to proceed? thanks to doug dutra by the way for his choke adjustment article. |
| Author: | SlantSixDan [ Sun Nov 26, 2006 10:07 am ] |
Certainly any loose nuts (e.g. all of us on this board! One of these gaskets will make a good seal much more likely. |
| Author: | 75dartcustom [ Sun Nov 26, 2006 10:09 am ] |
sounds like my best bet is to check these with a torque wrench, make sure they are at 10 ft lbs, and if so, then i need to take her back to my mechanic and have him install a non warped manifold. |
| Author: | SlantSixDan [ Sun Nov 26, 2006 10:16 am ] |
Or at least a thicker gasket, if the existing manifold isn't too badly warped. |
