It is currently Sun May 24, 2026 1:37 pm
 Post subject: Piston Rings?
PostPosted: Tue Apr 17, 2007 10:19 am
I went to the machine shop today to look at the head. The machinist suggested that with as much oil that had collected behind the valves, I might have blown rings. Is it possible to replace them without removing the block? Would it be a good idea to do it anyway while the head is off? If so, what replacement rings would you recommend? Thanks for your help.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Tue Apr 17, 2007 10:39 am
Replacing the rings really means rebuilding the bottom end of the motor. You might be better off swapping in a good motor from your slant pile.
(...or somebody elses slant pile)
PostPosted: Tue Apr 17, 2007 4:43 pm
SSRN National Champion
Unless this is a recently rebuilt engine that might suffered some kind of ring failue which i doubt becaust oil ring is the botem ring it is probaly has worn compression rings. The only thing that will fix that is a engine rebuild. Since cylinders wear like a egg shape after a lot of miles that is why 99.99 percent of the time on a street engine it will have to be bored larger to get it back round. Thanks Ron Parker :D
Bagels On Juice Im Bamboozled
PostPosted: Tue Apr 17, 2007 8:23 pm
True dat. :shock:
PostPosted: Wed Apr 18, 2007 6:21 pm
Damn Straight :D Thanks Possum
Bagels Juiced Im Bamboozled
