It is currently Mon Aug 10, 2026 11:26 pm
 Post subject: Oil sender sealing
PostPosted: Tue Apr 10, 2007 10:20 am
Does anybody use teflon tape or ??? to seal the threads of a suspected leaking oil sender? Or does that mess with the grounding effect (if there is one?)
PostPosted: Tue Apr 10, 2007 11:09 am
You do need metal-to-metal contact at the threaded junction. They don't tend to leak through the threads, they tend to leak through the (blown) sender itself!
PostPosted: Tue Apr 10, 2007 11:23 am
That would explain why it didn't leak before and does now. Thanks.
