It is currently Thu Aug 13, 2026 9:25 am
 Post subject: Run on
PostPosted: Fri Apr 13, 2007 12:03 am
I just drove my 68 d100 up to Canada this week. It has a problem where after exiting the freeway(or freeway speeds) and stopping, shutting the engine off, it has a tendency to run on and then backfire. Even when just shutting it down after driving around town it wants to run on. It has a supersix with the holley two barrel. What could be causing this? I can post pics of the carb tomorrow.
Excuse me, does this smell like chloroform to you?
PostPosted: Fri Apr 13, 2007 5:05 am
What are your timing and idle speed set at? There is a tendency to speed the idle up with the speed screw to compensate for the timing being set late. The wider opening of the throttle plates leads to the run-on. :shock:
