| Slant Six Forum https://www.slantsix.org/forum/ |
| Run on https://www.slantsix.org/forum/viewtopic.php?t=22703 |
| Author: | icaneat50eggs [ Fri Apr 13, 2007 12:03 am ] |
| Post subject: | Run on |
I just drove my 68 d100 up to Canada this week. It has a problem where after exiting the freeway(or freeway speeds) and stopping, shutting the engine off, it has a tendency to run on and then backfire. Even when just shutting it down after driving around town it wants to run on. It has a supersix with the holley two barrel. What could be causing this? I can post pics of the carb tomorrow. |
| Author: | slantzilla [ Fri Apr 13, 2007 5:05 am ] |
What are your timing and idle speed set at? There is a tendency to speed the idle up with the speed screw to compensate for the timing being set late. The wider opening of the throttle plates leads to the run-on. |
