It is currently Tue Dec 23, 2025 10:37 am
 Post subject: Engine swap question...
PostPosted: Mon Apr 09, 2007 10:15 pm
I have a 1964 Dodge pickup, 225 slant and three on the tree. I have a chance to buy a 225 out of a 1981 car that had an automatic. Can I put this motor into this truck? I don't think the flywheel will interchange. But is it just a question of getting a flywheel out of a circa 1981 truck? I would like it to be close to a bolt-in. Is this more trouble than it is worth?? Thank you in advance :?
PostPosted: Mon Apr 09, 2007 10:38 pm
The 81 engine will bolt into the 64 if you use the correct flywheel.
You will also have to swap your current oil pan and pick-up tube onto the repalcement engine.
PostPosted: Mon Apr 09, 2007 10:46 pm
Thank you for the quick reply! The 1964 flywheel wont fit the 1981 engine though, will it?
PostPosted: Tue Apr 10, 2007 6:10 am
Nope, different register diameter. Also check your 81 crank for a pilot bushing. By 1981 they weren't routinely installed at the factory.
If a MedAlert bracelet is the only bling you wear......You might be getting old.
PostPosted: Tue Apr 10, 2007 8:46 am
The good news is that the center register hole on the 64's flywheel is smaller then the 81, it can be machined-out to the larger size if you can't find a later flywheel.
PostPosted: Tue Apr 10, 2007 5:52 pm
Great!! Thanks for the input and all of the help guys! I will keep you posted!
PostPosted: Tue Apr 10, 2007 8:56 pm
If your crank isn't machined for a pilot bushing you can go to Autozone or any parts store and get a roller pilot bearing for a V-6 Dakota truck and use it. :shock:
PostPosted: Tue Apr 10, 2007 9:43 pm
Assuming your truck has the mounted bell housing, any 62 to
67 v8 flywheel will
work (if you slot one crank hole on the flywheel) and will center on the late 225 crank.
These flywheels need to be the right tooth count to match the direct
drive starters used with the mounted bell slave clutch system.
Since the trucks all went to the gear reduction starters after 71
those flywheels will not work.
I can check, I may have a 225 68 truck flywheel that should work...
let me know and I will dig it out.....
Also, if you have never done a engine swap on one of these trucks-----
you pull the trans and drop it frist, then pull everthing in front of the
water pump (radiator, fan ect....) loosen bell mounts
on the top one side, bottem on the other side, then pull the engine with bell
attached as a unit. May sound odd to pull engine with the
bell, but it is the best way...... detach bell after engine is pulled.
Flywheel must come off before the bell is removed from engine (there
are engine/bell bolts behind the flywheel on the \6).
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Sun Apr 15, 2007 5:33 pm
Well I picked up my '81 225 today. It looks like it is in pretty good condition and he had receipts for quite a few new parts like water pump, fuel pump, new carb etc. It is a 2-barrel and says "'Super Six" on the air filter. Any idea what the horsepower would be on this? Is it comparable to my '64 0ne-barrel engine? Also the crank is drilled for a pilot bearing so I hope the flywheel issue won't be too difficult to overcome. Thanks again and feel free to offer more advice!
PostPosted: Sun Apr 15, 2007 5:55 pm
The 2bbl gives, but the '81 camshaft and its retarded timing take away. It will pay you to pull the timing cover, put in a nice new timing chain and spend some time carefully degreeing-in the cam. Also spend some time recurving the distributor.
Users browsing this forum: Google [Bot] and 11 guests
