Best way to hook up hand-held start switch?
https://www.slantsix.org/forum/viewtopic.php?t=22756
Page 1 of 1
Author:  Jopapa [ Mon Apr 16, 2007 9:29 pm ]
Post subject:  Best way to hook up hand-held start switch?
If I get time tomorrow I'm going to do a compression check on my engine, and I was wondering where you guys recommend connecting the start switch? I would expect just the pattery pos. and the connection that the stock starter switch connects to on the starter relay. Is this the best way to go?
I second guess myself alot....for good reason.
Author:  slantzilla [ Mon Apr 16, 2007 9:57 pm ]
I hook my button up to the positive terminal on the relay itself, and to the starter terminal also on the relay. :D
Author:  Jopapa [ Mon Apr 16, 2007 10:51 pm ]
Oh sure, do it the easy way...
Note to self: look closer at the relay next time...
Author:  Pierre [ Tue Apr 17, 2007 12:43 am ]
I usually go to the relay coil as well. Either that, or if I don't feel like looking for my starter switch, a big screwdriver shorting out the two big relay posts work.
Come to think of it last time I did it I just kept walking back and forth between the plugs and cab using the column key.
